My phone neither charging nor turning on
I was using my phone normally and then it switched off and a white light started blinking and a triangle appeared. The battery was around 82%
I have a Moto z2 Play
My best guess without being able to look at the device is that it’s a battery issue. How old is the phone? If it’s more than a few years old then it wouldn’t be out of the question for it to need a new battery. Other causes could be water damage or the device just simply dying on you.
このアンサーは役に立ちましたか?
My phone is around 1 year old
Batteries in phones are good for about 300 to 500 charge cycles. It's entirely possible with the device being a year old that it's the battery. Some repair shops might try a new battery for you first to see if that's the problem.
過去 24時間: 1
過去 7 日: 3
過去 30 日: 9
今までの合計 243
