Why my iMac won't turn on?
I turn off my iMac when is updating and there is sounds like fan when I push the button.
Thanks for your help.
Check out the post below by Apple and see if there’s any useful info, thanks!
このアンサーは役に立ちましたか?
If your system is in the middle of an OS update you don’t want to shut the system down! Let it do its thing without disruption!
I fear you corrupted the system! Depending on what it was in the middle of you might be able to recover it using what @v3nuo posted above steps from Apple. If that fails to work you’ll need to bring your system into Apple to get them to fix it.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 144
