メインコンテンツにスキップ
2015 Retina MacBook Airの修理情報とガイド。モデル番号はA1534
281回答 すべてを表示
MacBook 12" 2015(820-00045) no display, no chime, no image
Hello, @arbaman @reecee @refectio and other experts!
Recently I received a dead MacBook 2015 12”. When I connect charger, no chime no image, no backlight.
  1. I tried measure every power line with multimeter, but I found missing voltage only on PP5V_S0SW_LCD, PP5V1_S4SW and PP1V05_S4SW lines
  2. I use my ThermoCam and compared the thermo image with good working board but images look the same. So I think there is problem only with image and backlight (maybe)
  3. I disconnect everything and connected a known good display but does not help
  4. I preventatively replaced U4700 but no change
On the internet I found, than a lot of people have same issue with this model. Is here any way how to fix?
board number is 820-00045
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Did you press the re-set button on the battery connector?
さんによる
sure man, also tried smc reset, reconnect battery
on the board is not present
EDP_BKLT_EN
EDP_PANEL_PWR
さんによる
コメントを追加
2件の回答
ベストアンサー
I haven't much experience on A1534 boards unfortunately, I have a dead board around for a few months now but haven't had the time to get deeper into it. Do you have an adapter you can try to plug into an external screen to help you point in the right direction ? The missing enable for backlight might be your issue indeed.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
sure i tried connect external display but no image :)
on the board are not present
EDP_BKLT_EN
EDP_PANEL_PWR
さんによる
コメントを追加
Sadly, I think your best option is to replace the logic board MacBook 12" Retina (Early 2015) Logic Board.
MacBook 12" Retina (Early 2015) Logic Boardの画像
製品
$249.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tomas さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 14
今までの合計 1,002
