メインコンテンツにスキップ
The GMT800 Silverado/Sierra 1500 and 2500 (non Heavy Duty) (light pickup trucks) were released in 1998 as 1999 models.
26回答 すべてを表示
What is rear diff oil burning up so fast?
My rear diff oil is black and smells almost immediately after changing it to fresh recommended oil.
The previous owner I believe never changed it but I have had it changed twice in the past two days.
both times it was black with only a 30 minute ride.
Also after driving on a dip the howling sound started and has not stopped even after the diff oil changes and a center barring mount change.
pls help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Unless you clean out all the old oil and the carbon build up off all the parts the oil is going to change rather quickly. If you’ve changed diff parts and are getting a howling sound you might need to change the shims as the backlash may need to be adjusted.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Jack Vampa さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 12
今までの合計 243
