How to repair keyboard keys?
Hello. Im facing difficulty while using few keys on in laptop keyboard. Few keys like X, 3,7 need to be pressed hard to 2-3 times to work. Other keys are working fine. What could be the issue? How can I repair this issue? Thank you.
この質問は役に立ちましたか?
4 件のコメント
Did you spill soda on the keyboard? It sounds like you need to wipe out the gunk that was left behind. It's an easy enough fix, you will need to make sure the device isn't plugged in and then drain the remaining voltage buy holding down the power button.
Abraham Luna さんによる
No nothing happened of soda spill incident. I once opened my laptop to change hdd. It's happening since then.
Roshanlal さんによる
Thank you so much.
Roshanlal さんによる
I got my keyboard replaced by Authorized Dell Executive. Its been working smooth since then. Thank you for your help.
Roshanlal さんによる
