メインコンテンツにスキップ
The Motorola Moto Z Force (XT1650) is an Android smartphone developed by Motorola. It also is known as the Moto Z Force for markets outside the US and has been available since July 2016.
31回答 すべてを表示
Replacement screws for display assembly.
So, I started to work on replacing my phones battery, and I got all of the screws out except for one, which decided to strip on me, I’ve already ordered the extractor set, and I’m wondering what kind of screw to replace it with, or if I can go without one screw.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
if all the other screws hold the component in place decently then you should be fine like i there were 4 screws and you extracted 3 , you would be “ok” unless is less than 3, then i suggest you try to find the screws
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
there were six screws, so i will just use five then.
さんによる
oh, well then you should be fine
さんによる
コメントを追加
回答を追加する
Patrick Hankins さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 4
過去 30 日: 5
今までの合計 60
