How to reset account live password
I have forgotten my microsoft password and i don’t have access to my recovery phone or mail. What should i do to get my account back.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
If you are having some problem while login into your Microsoft account there may be some reasons like: you have forgotten your password or you may have enabled two step verification on you account and you don't have your gadgets along with you to verify you. May be you are trying to login in any other device which is not a recognized device by your account.
Here are some easy suggestion that can definitely help you to get your account back:
By doing these simple steps if you don’t get your account back try to reset your account live password by below given method:
These are the steps for account live password reset:
If you still face any issues you can follow this article: https://bit.ly/2HeU0Bw
このアンサーは役に立ちましたか?
There is a process to force replace security information, go through the password reset page, answer as much security questions as possible, then the account system will start the replacement process, takes about 2-4 weeks before you are allowed to replace security info.
このアンサーは役に立ちましたか?
Account Live is a single spot to view and manage your Microsoft products and services. To start, you need to create an account by entering your email address, first name, last name, and other details. After entering the same, you need to set a password for your account. In case, if you forget the password of this account, then perform '''Account Live password reset''' process by following these instructions:
1. Visit '''https://account.live.com/password/res...
2. Enter the email address linked to your Microsoft account
a. You can also provide your Skype ID or phone number
3. Click Next
4. You will now receive a password reset code on your ID or phone number
5. Enter this code at the '''account live com password reset''' page to set a new password for your account
6. Retype the password to confirm
7. It’s done!
During this process, if you experience a glitch, then connect to Account Live support team and receive immediate fix. You can contact the support professionals as per your convenience because the team offers its services all day long.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 18
過去 30 日: 64
今までの合計 4,553
1件のコメント
oud telefoonnummer vervangen...
Eddy Herwijnen さんによる
