Dispaly cable Olympus OM-D E-M10 Mark II
The tilt display works in some positions, but in most - not.
If the problem is a damaged cable, which it may or may not be, you can get a replacement off eBay easily: https://www.ebay.com/itm/New-LCD-Flex-Ca...?
このアンサーは役に立ちましたか?
I found this video showing half of the cable replacement works. Does not appear to be easy:
https://www.youtube.com/watch?v=8wpLLklS...
Is is also not clear from the video if he ever managed to fix his camera.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 28
今までの合計 1,405
Me too. I will to try replace flex cable. Any suggestion for it?
montonm さんによる
Same problem here. Any alternatives to sending it in for repair?
Andreas Reischle さんによる
