メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
Preparing Automatic Repair with no loading symbol
I am on a iBuyPower, and I didn't put that in the device because there was no iBuyPower option, but it is stuck on Preparing Automatic Repair, with no loading, spinning, thing. I've waited around 20 mins, any help?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
6 件のコメント
What is an "iBuyPower"? Any one know?
さんによる
Hi @aactech ,
Perhaps it is a custom built or self built desktop with parts sourced from here
Cheers.
さんによる
Hi jayeff,
O.K that makes sense now.
さんによる
Just so you all know, I have finished fixing my computer, without deleting countless of personal files.
さんによる
What did you do to fix
さんによる
1以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
From your Comment is see you tried “Startup Repair'“. I would try this one at least three times. Some times the repair can take several steps before it works.
If it still does not fix the “Startup” then I suggest doing the “Reset this PC”
If From “Automatic Repair” select “Advanced options”
From “Choose an option” select “Troubleshoot”.
From “Troubleshoot” selcet “Reset this PC”
Once in “Reset this PC” remember to select the option to keep your files and reset Windows.
This will reinstall Windows 10 keeping your files.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you, but I am glad to say that I was eventually able to fix the computer. Also, an IBuyPower is a computer making company (according to google) Sorry if I wasted your time, but apparently, after a couple days of waiting for the Attempting Repairs, it finally fixed itself, somehow. Sorry if I wasted your time, just forgot to delete the question.
さんによる
コメントを追加
Reinstall windows if you have the software
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Eaglegrant さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 13
今までの合計 2,482
