The inside of my HTC Vive Controller charger fell out...
The inside of the USB type C charger fell out and now the controller will not charge, how can I fix this?
You would have to buy a new micro usb connector and unless you're very good with soldering and have a micro soldering tip it would be challenging. Finding the correct connector if you use your current one to look for which type you need. It looks like one with 4 through hole mounts and the standard pin out for the charger.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 164
