It sounds like you either need a replacement earpiece speaker or top components flex cable replaced. If the earpiece is not connected properly, any time it attempts to make sound through that speaker, it restarts the device. Should be as easy as top flex cable and earpiece replacement.
Front camera cable must have been ripped, this would be a fault caused by the proximity sensor somehow being damaged. See if it reboots with front camera disconnected.
Siri also uses proximity sensor so see if it reboots when you try to run Siri.
3 件のコメント
I may have a problem with the battery. (Really doubt that it’s the battery) it probably needs logicboard repair.
Owen Baker さんによる
Jonathan Mechels さんによる
There have been a lot of problems with the dock connectors. Does it do that with a regular iPhone charger?
Ian Shalongo さんによる
