メインコンテンツにスキップ
AppleのPad 6のWi-Fiのみのモデルは2018年3月に発売されました。32GBと128GBの容量オプションがあります。9.7インチRetina ディスプレイと64ビットA10 fusionチップを搭載しています。
Apple Light Mod Question
Hey everyone,
i am an active member to the ifixit forum, however I have a question about a mod I’ll be performing. I’ve done several logo light mods to the iPhones, however there is no mod available for the iPad. I am able to remove the IPad 6 logo and have it 3D printed so it would be transparent so I can install leds behind it and the logo would light up. My question though, where would I solder the LEDs power source? Would it go somewhere on the LCD Panel or somewhere on the board such as the backlight filter? I only want the logo leds to turn on when my screen is lit and I’m using it. After it’s locked, the logo would turn off.
can someone lead me where I would solder the logo leds on the IPad 6 to make this mod possible? I already have the transparent logo and the leds working with my meter, and the ground to any screw, just lost on where I would solder the positive lead side to the iPad for current only when iPad is being used…
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You could try to solder the leds to a ribbon cable that could take power from the battery, like other mods for the iPhones, if you had a cable like so from a broken mod kit.
Update (03/05/2019)
Run a jumper wire from the logo to PPLED_OUT_A that drives 20volts to the LEDs should work.
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
It’ll work off battery but I want it modified so it only works when the screen receives power and shuts off when you lock the screen. I was told you can solder to the L4601 anode filter which would make this mod work
さんによる
It'd probably require a specific splice to the LCD power to have it work the way you need it.
さんによる
I’ve found a solution I think will work. Running a jumper wire from the logo to PPLED_OUT_A that drives 20volts to the LEDs should work
さんによる
コメントを追加
回答を追加する
Daniel さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 9
今までの合計 189
