メインコンテンツにスキップ
統合されたディスプレイを持たない一般的な据え付けのコンピューターです。
2134回答 すべてを表示
Why do my CPU and case fans spin but no startup?
Hi, so I recently finished a PC build and I went to power it on the fans spun, but no startup.
I have tried unplugging the PSU and holding power for 30 seconds and that didn’t work. Does anybody know what is wrong and how to fix it?
Thanks in advance!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
For me a bluetooth pci card was like 1mm Loose. -.-
さんによる
1)Just check Ram (If Fan not spinning)...
2) Replace Motherboard (If Fan spinning but no display
Next time use Stabilizer to avoid motherboard fault
さんによる
In my case, the issue was the front panel IO. Unplugging it from the mobo resolved the problem on Optiplex 9020 MT.
さんによる
コメントを追加
6件の回答
ベストアンサー
Have you tried DrGlowire’s suggestions?
O.K., now unplug the power cable from the power supply, gently remove the silver “coin” battery (should have at least a 2.6v charge) from the motherboard. and press power button for 30 seconds. That alone should clear the BIOS but you can also do as listed below.
If you know where they are, short-out the two pins with the jumper OTHERWISE just leave the computer unplugged for at least 10 minutes or longer.
This will reset the BIOS setting to the “new” computer defaults.
Put the "coin" battery back in, plug power cable in and switch on.
If this doesn’t work you MAY have a bent pin on the CPU or the like.
このアンサーは役に立ちましたか?
スコア 7
9 件のコメント:
Thank you for the advice. It solved my similar issue
さんによる
Thanks, this solve my problem.
さんによる
What do I do with the battery, do I plug it back in or get a new one?
さんによる
@Joshua Wilson
If you're asking about the RTC (Real Time Clock) coin cell battery then measure its voltage when it is disconnected from the motherboard.
It's a 3.0V DC battery, if it is <2.6V DC replace it. The RTC battery maintains the BIOS setting when the power is disconnected or turned off from the desktop.
When the battery voltage gets below 2.6V then there is a chance that the settings can become corrupted which can prevent a normal start when the desktop is turned on.
It is a non-rechargeable Lithium battery and it usually lasts for 4-5 years before a problem may occur, but this can vary. I've had some that lasted 7 years and others 4 so it is always prudent to check the voltage anyway.
さんによる
@jayeff how do I test to see what voltage the battery has? And would I need to put the battery back in after the 10+ minutes is up? When do I put the coin back in
さんによる
4件以上のコメントを表示
コメントを追加
There are a few things to try. You can check the voltages coming out of the power supply, you can check the cables to make sure they are seated properly.
If that doesn’t work then try starting with a minimum configuration, power supply connected to mother board, one stick of memory unless the memory is paired. Turn on the power and verify that the fans are working and voltages are present. Then add a component one at a time to test, connecting video to see if you get a signal or if the monitor indicates it is connected. From your description of using random parts I would guess that one or two parts may be defective or incompatible.
このアンサーは役に立ちましたか?
スコア 2
3 件のコメント:
should keep my desktop plug in while doing the 10 seconds thing?
さんによる
@Magalona Family
All power needs to be disconnected/removed from the PC before pressing the PC Power On/Off button for ~30 seconds (sometimes 10 seconds is not long enough) to reset the BIOS in trying to fix the PC not starting problem
さんによる
forget the above just look at your power settings in windows and make sure your power button iswitchs set to off and nothing else, even on the "power setting"and disable any windows boxes below your power setting in that window pane because some of them will be ticked by default. and that is the problem.It took me years to figure this out even after renewing my power button on my desktop computer-Asus 2013.I had changed the power settings a few years ago and had this problem since.i solved it in oictober 2022.
さんによる
コメントを追加
Any beep codes after turning on?
Does drive light come on?
Any flicker, etc. on monitor screen?
Have you tried unplugging everything except 1 RAM card (alernate these) and power supply?
Graphics card - on board or a card in slot?
Most motherboards have a two pins that can be shorted with a jumper that resets the BIOS or remove battery to clear .
Have you tried various components in another working system?
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had issue with the ram.. 1 of the ram stick was faulty. Taking the faulty ram out solved the issue for me.
Mine was 1 year old pc. Not new setup.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hard drive plugged in? Loose RAM? Bad PSU? Corrupted BIOS?
Add a comment if there’s anything specific about the machine.
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
The hard drive is plugged in, the ram is brand new, and the PSU is also new. Also how would I fix corrupted BIOS? The rest of the parts of the PC are random parts I had around(Motherboard, CPU, case). I have used the PC before, and it worked. I just went to turn it on and this happened.
Thanks in advance!
さんによる
I think for a corrupted BIOS, you can download a new revision of it and burn it to a flash drive, than try to boot from USB. If not... buy a new motherboard. *sigh*
さんによる
Is there an OS on the drive? Because it could not be detecting. Also, if there's a graphics card, and your monitor is plugged into that, try switching to the onboard video ports on the mobo. (If it has any)
さんによる
I just upgraded to a new CPU, motherboard, and ram. I turn it on and nothing happens the quick debug lights don't show anything so I don't think it is any of those things. All the parts are new and I have an SSD with windows on it. When I plug in the HDMI cable I get a no signal alert on my monitor. The monitor works on other computers as well. I don't have any spare parts to test with also.
さんによる
@CHARLIE FLORY
More info is needed to help you.
Make and model number of motherboard.
Make and model number of CPU
Have you checked that the connections are all OK?
Check that the PSU turns on by performing the paperclip test You can also check if the PSU voltages are all OK if you have a DMM (digital multimeter)
さんによる
コメントを追加
check your power settings in windows and what the start button does.I changed to high power setting and little did i know but windows has further default settings when you choose this and so i had great difficulty booting.The computer would start and the fan come on but nothing else just a black screen.I tried a new switch with restart button and this worked after using start button.The problem was solved by going into windows power settings and unticking any boxes below that setting on what the power button does.This solved years of this problem for me.It was not the memory or power supply at fault.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Random _User_101 さん、ありがとうございました!
統計データ:
過去 24時間: 96
過去 7 日: 638
過去 30 日: 2,855
今までの合計 176,007
