device is googled locked due to reset.
the tablet was purchased at a pawn shop and my son did a reset due to his pass word or code and now the tablet is asking for the email with the original google account
Sins you don’t know the that owner it doesn’t look like you will be able to get it. Sorry
このアンサーは役に立ちましたか?
That’s a result of the previous user not logging out of their account and not doing a factory reset before selling it. As of Android 5.1, all Android devices have what is called FRP for Firmware Reset Protection. There's a way to bypass it, which is a pain, but it can be done. I came across that same issue when I tried to reflash it. Here’s a way to do so. It must be followed carefully. After that, you can do a factory reset and be able to use it. Here’s a link of how to bypass the FRP:
このアンサーは役に立ちましたか?
I Just recently acquired the Samsung tab e SM-T378V (Verizon Version) from a friend that was FRP google locked to an account that no one has access to and haven’t in years. Verizons Stuff usually is also a bit more challenging than an underdog company. With that being said, There is a solution and it can be bypassed many different ways. Me personally I used a Odin method which requires basically flashing the service back to its original state, like it was brand new. When I rebooted it was like a Brand new tablet and asked for a google account or create one. Odin method is probably the hardest to do, so I suggest if you wanna unlock it and don’t mind a little time dedicated to research online, it can be done!!!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 16
過去 30 日: 63
今までの合計 1,332
