メインコンテンツにスキップ
より早い処理スピードを可能にしたiPhone 3Gのアップグレード版です。このデバイスの修理は3Gと似ており、標準のドライバーと開口ツールが必要です。モデル番号 A1303 / 16 もしくは 32 GBの容量 / ブラックもしくはプラスチックの背面ケース
1500回答 すべてを表示
No success after replacing battery, what next?
Hi I dropped my iPhone and there is a small crack in the screen and on the back case.
The screen didn't break and the phone was still working but it stopped charging and wasn't recognised by the computer.
Eventually the battery died and the phone hasn't turned on since.
I have replaced the battery with a brand new one, what I wanted to ask is:
Neither batteries will charge, I assume that there both carry a charge, albeit a small amount to power the device so is this a logic board issue? or the dock connector?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
okay, I will replace the dock connector next guys, thanks.
Surely the new battery I bought contained enough charge so I am curious as to why it wont switch on - even with a faulty dock connector?
(update) iPhone is able to power on from USB plug into the wall, but reboots after two minutes, and switches off when unplugged.
さんによる
it should have..if all your connections are correct and there was no other damage. use a multimeter to measure the charge in your batteries..
さんによる
コメントを追加
2件の回答
最も参考になった回答
Yes, replacing the dock connector is definitely the way to go, and it's a really easy fix. Here's a link to the guide.
All you need is:
the dock connector
a Phillips #00 screwdriver
a small scution cup
and a spudger
Good luck!
iPhone 3GS Dock Connectorの画像
製品
$19.99
Spudgerの画像
製品
Spudger
$3.99
Phillips #00 Screwdriverの画像
製品
$5.49
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
The rebooting after 2-min problem also happens if u put in a wrong battery. i.e. if u put in a battery for 3G in 3GS instrument. Double-check the part number and it's origin
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
no way さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 3
今までの合計 2,961
