Very Slow with only 2GB RAM onboard Asus Vivobook max X541SA
This laptop only has 2GB RAM onboard, is it possible to increase this and how?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Yes. Up to 8 GB SDRAM , DDR3L 1600MHz SDRAM Onboard Memory
The RAM slot is on the under side of the motherboard!
このアンサーは役に立ちましたか?
Hi @aactech ,
It appears as though not all 541 models are the same.
I posted a video earlier showing the 541 UV RAM replacement and as you stated the slot is on the back of the motherboard.
When corrected by the OP that it was not the same as theirs I posted one of a 541SA teardown and there is no sign of a RAM slot on either side of the board.
In the video, to me there are signs of the RAM being soldered directly to the board, but hey. my eyes aren't what they used to be.
Cheers.
Your eyes are fine and I think our friend the soldered on RAM.
Sorry but you are out of luck. You have the “rip off” model.
I’m guessing it is a “Chromebook” for school children.
Hi,
It seems that you cannot upgrade the RAM in your laptop without replacing the motherboard.
Here's a link to a teardown video for your model showing that the RAM is mounted directly onto the motherboard.
Apologies for the earlier post
このアンサーは役に立ちましたか?
This is a different model to mine, mine is the X541SA with 2GB on-board RAM that I want to
I know I’m late for the party, but here’s one I opened up recently. Windows 10, 2GB RAM non-upgradeable. Not quite a Chromebook plaything, but rather a cheap piece of junk for Adults who should rather have spent some extra for a proper notebook.
このアンサーは役に立ちましたか?
You may have to install more RAM, but if you don’t want to, there are still some ways to improve your laptop’s performance by manipulating your computer’s hard drive.
Your computer’s performance should improve.
このアンサーは役に立ちましたか?
Ram is soldered onto the mother board.You would have to solder another ram onto mother board .
このアンサーは役に立ちましたか?
Any idea where on the motherboard, I cannot see it, If I can find it I can upgrade it lol
過去 24時間: 7
過去 7 日: 28
過去 30 日: 57
今までの合計 4,324
