メインコンテンツにスキップ
AmazonのBluetoothスマートスピーカー。2014年11月6日に発表されました。AmazonEcho SK705DIは、音楽再生、ニュースの閲覧、リストの作成、質問への回答など、さまざまなタスクを管理できる音声起動のクラウドベースのアシスタントを備えています。
44回答 すべてを表示
WiFi dropped connection and no longer works
My Echo dropped its WiFi connection, and is unable to reconnect to my network. I manage my own network, and have changed nothing on any configuration. In fact, my MAC filtering explicitly allows this device to connect, and I even have an IP address reserved for it (Echo gets it's address via DHCP, I assume). Absolutely nothing I do can get it to connect, and I have performed a hard reset on the device as well as made sure my router firmware is on the most current version. I also power cycled my router, to rule out anything obvious. The only thing I can imagine is maybe the device isn't being allowed through a specific port to connect to Amazon's servers? Not sure what port it might be trying to use. Any insights out there? Things I may have overlooked?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Problem solved folks. I use a hidden network and don’t have SSID broadcast turned on. Apparently the Alexa app cannot connect to hidden networks. You have to broadcast the SSID during setup, and can hide it again once you’re connected. However, if your connection drops for any reason, the Echo will no longer be able to connect.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Greg Johnson さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 80
