Need to remove text files from a PowerBook 540.
The floppy drive won't work. Can I somehow connect it to a PowerBook G3 Wallstreet? thank you. Beth
この質問は役に立ちましたか?
この質問は役に立ちましたか?
How about connecting your PowerBook via Ethernet using: AAIU-15 to RJ45 transceiver. Then you copy off your stuff to another Mac or file server.
The only other way is to replace the floppy drive Apple P/N 076-0462
このアンサーは役に立ちましたか?
Thank you for answering!!
I’d like to replace the floppy drive. I have search for a replacement floppy drive but none to be had on ebay or fixit either. any suggestions as to where i look for part Apple P/N 076-0462?
Sadly, you'll need to search out another PowerBook to steal it from. Parts for this series is hard to find these days.
thank you, Dan. Yes.. I've been looking for just that.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 184
