メインコンテンツにスキップ
A1150 will not charge. Can one replace the charging circuit?
I have a used A1150 (eBay) and it has never been able to charge at all. I followed all the troubleshooting guides from Apple's tech pages and went to my local Apple tech store. They switched the Magsafe and swapped the battery. Their battery worked fine but the Magsafe charger still did not work (it holds a very dim green light when attempting to charge). They said it probably was not the logic board but the actual charging circuit. What part(s) would I need to replace the charging circuit? can one replace the charging circuit without soldering?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Do you mean to say they swapped the left i/o board? (the part with the magsafe board)
さんによる
コメントを追加
4件の回答
最も参考になった回答
yes, the charging circuit should be on the left I/O Board, you can find the repair instructions here - replacing it does not involve soldering.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
They only switched the Magsafe adapter not the left I/O board. Sorry for not qualifying that. @rab777hp
Great tutorial @bac. i will grab a few tools and find a replacement left I/O board. Thanks!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Are you sure it's not the battery? The computer end of the Magsafe on this model of Macbook Pro glows red when the battery is depleted and green when fully charged.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
My bet would be the Left side I/O board. Not difficult to replace, but parts getting hard to come by!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Steve 10 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 5,790
