メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2265回答 すべてを表示
Battery at 1%, searching for carrier and slow boot
Hi
A while ago I bought an iphone 7 (phone 1) that was used that had a broken screen. When I got it (phone 1) it wasn’t booting as it should, so I took out the battery and tried it in another iPhone 7 (phone 2). When I tried the battery in (phone 2), it (phone 2) wouldn’t boot normal either, and when it (phone 2) booted up the battery only says that it (phone 2) has 1% charge and when the lightning cable is plugged in it doesn’t say that it (phone 2) is charging. It isn’t recognized by iTunes neither. Also (phone 2) only stays at “searching“ on the top left corner (searching for carrier network). It (phone 2) is also really, really slow when in use. (Phone 2) worked as it should before I tested the battery from (phone 1). I have also confirmed that both of the batteries from (phone 1) and (phone 2) work as they should. (Phone 1) won’t recognize any audio device, so I suspect that it (phone 1) has a bad audio IC? But my question here is actually what is wrong with (phone 2) that worked before I tested the battery from (phone 1)? I am thinking that it might be the charging IC, but I am not sure.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Phone 1 definitely has the audio IC issue.
Phone 2 I would still try a new battery first. Then move onto the lighting port being a possible issue as well because of the searching issue.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
I have tried a new battery in phone 2, but that didn't help. What has the lighting port to do with the searching problem?
さんによる
The speakers work as they should in phone 1 also.
さんによる
The lightning port has an antenna in it that connects to the logic board.
さんによる
Try dialling *#06# on the searching phone. If nothing displays and/or IMEI and modem firmware is not present in phone settings general about the phone has a baseband circuit fault on the logic board.
さんによる
コメントを追加
回答を追加する
Anders Tellefsen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 80
