メインコンテンツにスキップ
Repair guides for the the LG V30, released in September of 2017.
20回答 すべてを表示
What glue to fix corners
I have broken my screen. All 4 corners are smashed. But no cracks run throws visible display. I want to glue corners to prevent falling pieces apart. Maybe some epoxy? Now it is only in surrounding part of screen. So something what helps keep it as long as passible without continuing falling apart. And then i would use a 3d protective screen glass. Which i hope helps screen also not to continuing screen decomposition.
What glue use for the corners?
Is my plan whit a protective glass use as plaster to add display bending duratibility totally nonsense?
I know i eventually will let change display in service shop. But for now i can live with this demage. So a cheaper temporary solution is what i want for now.
Thanks for any advice.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Try B7000 or E6000
https://www.walmart.com/ip/B7000-50ml-Mu...
E6000 Adhesive Glue
A clear industrial strength adhesive. Bonds metal, wood, fabric, glass, ceramic, and other surfaces.の画像
製品
E6000 Adhesive Glue
$2.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Filip Raab さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 142
