Why is my airbag light flashing
I have replaced the airbags in my truck and now it starts but throws a code 1-9 what causes that
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The flashing means that there is a fault with the system. You can read the number of flashes and it will give you a code, what are you getting?
このアンサーは役に立ちましたか?
Dealer may have to recalibrate.
このアンサーは役に立ちましたか?
I AM NOT A LICENSED MECHANIC OR BODY TECHNICIAN.
Airbags must be done carefully and calibrated by a dealer Usually. Done incorrectly could result in failure to deploy or deploy to forcefully resulting in serious injury or death. The same results if it fails to deploy at all therefore failing to prevent serious injury or death. Most insurance companies to my knowledge total a car once airbags deploy. Liability is much to high. Id let the certified licensed dealer deal with it if they will. Consider the liability involved. Did you try resetting computer? Or perhaps the triggering device is failing.
Try changing the impact sensor
このアンサーは役に立ちましたか?
I have 2004 Ford F150 Air bag light started flashing code 33 after I replaced oil pan gasket. Can anyone please ? tell me what to next ?. I spent $100.on front crash Air bag sensor. I have spent hours laying underneath my truck asking God to show me what is wrong. I believe God had me to ask for help from you good people.
33=Passenger Side Air Bag Circuit High Resistance or Open, this usually means a wire is broken or damaged. Often simply unplugged see if you can find a Circuit diagram. Then trace the wires. I have found many times it was simply a disconnected connector.
過去 24時間: 0
過去 7 日: 6
過去 30 日: 44
今までの合計 2,449
