メインコンテンツにスキップ
The Nikon Coolpix S8000 is a 14.2 megapixels camera with a 10x zoom and a 3.0 inch LCD
6回答 すべてを表示
My LCD screen is black, but otherwise the camera works perfectly.
I have replaced the LCD screen.
All functions work except the display function - I have taken photos and videos without a problem, except I can’t see what I’m taking. I can’t view old photos either. With the SD in the computer I can see what I have taken and old photos.
I don’t remember dropping it or causing it any unusual trauma.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi,
Do the menu options appear OK on the LCD screen.
If also not, with the camera turned on, try shining a torch at an angle close to the LCD screen to check if there is an image there or not.
If there is, you have a backlight problem.
As you have replaced the LCD screen, it is either a faulty backlight flex cable motherboard connection (or connector) (see small cable from LCD screen to motherboard, Step.8 of the ifixit Nikon Coolpix S8000 LCD Display Replacement guide or there is a problem with the backlight power supply from the motherboard.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Waldo Lives さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 28
今までの合計 535
