メインコンテンツにスキップ
2015年3月にアップデートされたAppleのMacBook Pro 13" Retina Display Early 2015 はモデル番号はA1502、第5世代のIntel Core i5と i7プロセッサーが特長でForce Touchトラックパッドを備えています。
1185回答 すべてを表示
Backlight stops working, intermittent. What can I do?
I have the MacBook Pro 13 RETINA A1502 2015
and the motherboard is at bottom.
Laptop works fine, then after a while, the screen goes out. I an see the screen if light is shown through the apple etc, so there is content, but no light. Then I open the back cover and press on the corner in upper right area where you see the display connection and also undo that clip and put back. Then the laptop works again for few days. Then light goes out. Is there some small part I can replace? or something I can do on that motherboard? I don't see any rusty areas or loose connections, it all looks fine but I assume a loose connection somewhere. Trying to solve without having to get new logic board.
Thanks for your help
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Maybe a part broken solder joint, sometimes a bump can do that, or it’s a failure in the backlight circuitry, not very common but nothing is really perfect on this planet, we reached the moon half a century ago and saw a shuttle bursting in the sky over thirty years later. Intermittent failures are the worst to deal with, but in any case it seems a board issue. You’ll probably need a logic board repair or replacement which, given today’s screen prices is not the worst alternative.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
maybe the ccfl light or whatever it is is damaged or you blew a fuse
このアンサーは役に立ちましたか?
スコア -2
1件のコメント:
Yes, whatever..uh..
さんによる
コメントを追加
回答を追加する
pcgeek さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 6
過去 30 日: 8
今までの合計 552
