replace my digitizer screen now the screen won't light up
replace my digitizer screen now the screen won't light up but if I plug it on to a monitor i can see it?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Did you disconnect the battery before installing the replacement screen?
このアンサーは役に立ちましたか?
No, I did not.
That usually means the backlight fuse has blown. Shine a flashlight behind the apple logo of the screen and see if it displays a image on the screen while it's on.
If yes the macbook will need to be taken to a reputable macbook repair shop to get it fixed.
Try reseating the display cable with the battery unplugged and see if that helps.
Thank you and have a good day.
I feel dumb, I thought this was a MacBook air sorry.
You may have just missed a cable. At least graphics card works as mionitor works.
Go over the steps again, slowly with good light. Some times the little ribbon cables can be tricky.
このアンサーは役に立ちましたか?
Thanks a lot.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 183
