メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1778,1784。 GSM かCDMAの32、128、256GBがあり、色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラックがあり。
1364回答 すべてを表示
Why does my phone only start charging once it’s dead?
My phone, no matter what outlet it’s plugged into, will only charge if the phone is dead. Once it’s dead, it’ll start charging, keep charging once it’s on again, and stop when I unplug it. But I can’t begin charging it again until it’s back to being dead. What’s going on? Is it my phone or the charger?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
3件の回答
ベストアンサー
When troubleshooting charging issues, I would do the following (in order):
  1. Always try another Lightning cable and charger, preferably Apple original or MFi certified units.
  2. The Lightning cable 8-pin connector should be sitting flush with the housing and completely inserted. If it is not, there could be lint/dust/debris inside the port impeding a proper connection. You can clean it out with a toothpick, fine point tweezers or a dental pick. Just be careful not to damage the pins inside the Lightning Port.
  3. Change the battery. The battery is the weakest link in the entire phone and certainly for charger related issues. It is also the easiest thing to replace. Use a battery utility, such as coconutBattery (for Mac) or 3uTools (for Windows) to test the battery prior to removal. Anything less than 70% of design capacity will require replacement.
  4. If the battery is in good condition, you can use a USB Ammeter to determine if the phone is really drawing current when it says it's charging. If it isn't drawing current, then I would change the Lightning/Charge Port.
  5. If a new battery and charge port still don't resolve the issue, then you either have faulty replacement parts (possible) or a logic board issue. There is an IC (commonly referred to as Tristar) responsible for communicating with the charging device and uncertified chargers can damage it. Unplug the battery and connect a known-good (preferably Apple original or MFi) charger to the phone. A properly working phone will show an Apple logo and boot loop. If the Tristar IC is bad then the phone will not do anything.
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
Wasn't much help for the answer he was looking for. I'm having the same problem. My charger works while it's dead but as soon as IOS boots up, it doesn't work.
さんによる
コメントを追加
My phone charges when it dead but not when on what is going on?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I think it is better issue, while you charge your phone please be safe.
さんによる
コメントを追加
@jayden2020 SAMEEEEE NAJEJDJKEK
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gabe LaSalle さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 13
過去 30 日: 119
今までの合計 15,896
