メインコンテンツにスキップ
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
146回答 すべてを表示
Is it possible to replace a contact spring on Motherboard?
Hi:
I received an LG G5 model VS987 phone. It was reported the power button did not function but on closer inspection I found 3 contact springs on the motherboard that are broken- these connect with the power button on the back panel. I have safely removed the 3 broken contact springs, and removed three good ones from another motherboard for replacements. But, how can I safely solder the new contacts to the good motherboard? Anyone done this already?
Thanks!
Tom
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Thanks for your input…
Actually I`ve started researching SMD rework stations (uses hot air), that is how I will go. All this is still a bit new to me.
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Just use good tweezers and hot air at about 450c should do the
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
Is there a video you can post on where the motherboard is broken? I have the same issue with my power button which I've already replaced yet it is still not working.
さんによる
コメントを追加
回答を追加する
Tom さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 213
