How do you change out a charging port?
A friend has a Huawei XT (H1611) and the charge port springs have deteriorated. How can I help him change out the port?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @jimgentry ,
Here’s a link to the ifixit Huawei Ascend XT Speaker Replacement guide.
It is useful as it shows how to open the phone so that access to the micro USB charging port is possible.
Here’s a image taken from Step.5 in the guide showing the USB port. It appears as though it is supported in position by a bracket but I think that it will be a SMD (surface mount device) type component and you will need SMD tools and expertise to do the repair.
(click on image to enlarge for better viewing)
Here’s a link to just one supplier of the part. It is shown just to give you an idea of what the part looks like and its’ cost.
There are other suppliers online that may suit you better. Just search for Huawei Ascend XT USB connector part to get results.
If the SMD repair seems too daunting, contact a reputable, professional mobile phone or electronics repair service and ask for a quote to do the replacement of the USB connector only. You provide the dis-assembled phone and new USB connector and you will do the re-assembly after the repair. This should reduce the cost to you as they don’t have to spend time opening and closing the phone or sourcing the correct part. Just a thought.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 5
今までの合計 428
