メインコンテンツにスキップ
A 10.1 inch Samsung tablet computer with a 1.4 GHz processor, 1280x800 pixel LCD, and 149 ppi multi-touch display. The model number of the device is GT-N8013ZW. Released August 2012, repair of this device is straightforward.
127回答 すべてを表示
2012 Samsung Galaxy Note 10.1 with slow charging issue
I cannot seem to get this device to charge at a decent rate. When plugged in, it only pulls 0.83 A at 5.65 V. I have installed a new battery and have also reset the device, several times, each time it works marginally better for a while, then back to slow charging issues again. I have tried several different Samsung charging units and cords, all with the same outcome, slow charging.
Should I be looking for a deeper issue?
Thanks for your help.
JK
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
If you have done all the steps like changing battery and resetting. It seems more like a motherboard level issue instead of a battery / charging cable issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I find that a lot of the time the battery is “Below voltage” You will to connect a power supply directly to the battery pins in order to boost it to a level it will charge, Plenty of guides on how to do this
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
J.K さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 13
今までの合計 1,710
