How do I Factory reset
Could anyone please help me with factory reset on my radio avh-200ex
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @lyons4ever ,
According to the user manual (p.11) you need to turn the ignition to OFF and press the Reset button with a pen tip or other pointed tool, to reset the settings and recorded content back to the factory default settings.
Here’s an image taken from the manual that shows you where it is.
(click on image to enlarge for better viewing
このアンサーは役に立ちましたか?
I'm having the same problem with my avhx3600bhs pioneer dubble din as well I have no gear with a wrench setting to factory reset mine not microprocessor reset like that person posted I have tryed everything with no luck can anyone pls help
Here's a link to where the reset button is located on your model.
The manual is applicable to your model - see p.1
The reset button location for your model is shown as #1 on the bottom front display image on the left side of the page.
The procedure is shown on p.48 - Resetting the microprocessor.
resetting the Sirius XM see p.16
Resetting the video code number see p.39
I've searched the entire manual I need a full reset so I can get it out of standard mode and switch to network mode I need it reset to the setup menu when u first install the unit nothing has worked I even installed a diff dubble din n when I put mine back still no luck. Pls help and thank you so much for ur reply n time much appriciated
Did you try resetting the microprocessor with the engine switched on or at least the ignition in the Acc position?
Thank you for you're reply but I have done a microprocessor reset and it only resets the settings I need it back to the setup menu like the first time u hook it up I remember there is a 3 or 4 buttons u have to hold same time turn ign off n on while holding the buttons but I don't remember which buttons it is nothing else works I tryed litlerly everything with no luck does anyone know which buttons to hold pls I love this unit n don't want to have to buy something else
過去 24時間: 2
過去 7 日: 39
過去 30 日: 140
今までの合計 2,279
1件のコメント
Locate the small reset button on the front panel of the unit. It's typically a tiny hole marked "Reset" or something similar. You may need a paperclip or a similar tool to press the button.
Find more: https://windupradio.com/reset-a-pioneer-...
RV Zone さんによる
