メインコンテンツにスキップ
モデル:CUH-ZCT1は、2013年11月にSony Computer Entertainmentから発売されました。このコントローラはSix-axis、3.7 Vリチウムイオンバッテリーを採用しており、修理は複雑ではありません。
388回答 すべてを表示
Faulty analog sticks - only up and down axes on left and right
Hello
Im trying to repair controler (magma red version) with faulty analog sticks.
Only vertical axes are dysfunctional -they go both “up“.
I connected them to PC and its shows me this in neutral position:
Also if i put some pressure to right stick - like almost hitting R3 it then stabilizes like it should work in neutral position - and funny thing - pushing it also affects the
What i tried to do is clean potentiometer “disks” on both those axes. It didn’t changed anything.
However sticks look like they are covered in some… slime or oil.
I recorded it and sent it to youtube.
https://www.youtube.com/watch?v=Wokj0D1p...
If you look closely you can see its almost glowing.
So my question is - is it some kind of oil or lubricant put on purpose or can it be soda someone spilled out?
I opened about 3 or 4 dualshocks and have never seen something like that - however i havent yet seen sticks with black plastic parts - only those “white and green type”
I also found something like this near charging port and i was able to scracth it from PCB (no harm done).
So if it is some soda how can i clean it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I had something similar happen recently to one of my controllers. I did basically the same thing you did only I de-soldered the whole stick to clean the potentiometers, but did not get any improvement. The only thing which worked for me was to de-solder the whole analog stick assembly and solder in a new one.
As a side not I also saw a goo on my sticks, but after replacing the stick and getting a better look at the stuff I just decided it was some kind of lubricant from the factory.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
win.fatal.error さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 29
今までの合計 195
