Why cant I photocopy long bond paper?
i can print long bond paper thru my epson l360 but why cant i PHOTOCOPY long bond paper with it. it will cut some part of it
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
Try scanning a long bond paper document using the computer to control the scan and check the result.
Scanning and copying use the same hardware in the printer, the difference being that copying prints the image of the document straight away, whilst scanning stores the image and allows you to elect what to do with it
If it doesn't come out correctly either when viewed on the computer etc then here's a link to the user manual.
Scroll to p.77 to view the procedure what to do when the scanning area is not correct
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 31
今までの合計 3,548
