Why is ny battery not charging
Why is my battery not charging?
You need to check the charging module, the charging port and the battery itself.
このアンサーは役に立ちましたか?
the same applies to V110-15ISK Laptop (Lenovo) - Type 80TL?
First thing I would do is try another charger, otherwise it'll be battery if you see the battery health wear level being over 40% which you can check with HWMonitor.
maybe your cable is broken and the you habe to buy a new cable or repair it
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 382
