メインコンテンツにスキップ
Kinect is a gaming peripheral for the Microsoft Xbox 360. It allows for audio and video input to let the player be the controller.
What are the physical dimensions of the Kinect device?
What is the height, width and depth of the Xbox Kinect camera, and does the cable require you additional clearance from the wall beyond the overall depth of the device?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Of course you are asking this because you want to either repair it and/or incorporate your Kinect into a different entertainment center, thus making it repair related? ;-)
さんによる
The height, width, and depth of the Kinect itself should be listed in its user manual. Look through it to see if it's listed.
If not, a search on Google should bring it up.
さんによる
コメントを追加
2件の回答
ベストアンサー
Michael Emery, just measured mine :
Length 11"
height 3"
depth 3" at the widest part (the base)
the cable exits from the rear of the base, so you would have to give it some extra depth to accommodate it. Good Luck and I hope this helps.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
420 cm hieght
420 cm lenght
420 cm depth
just measured her up braz
このアンサーは役に立ちましたか?
スコア -1
2 件のコメント:
Thank you this helped a lot
さんによる
@blazeit your measurement make the Kinect a cube. You want to double check this? You also want to refrain from having your super ego vote up your wrong answers.
さんによる
コメントを追加
回答を追加する
Michael Emery さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 22
今までの合計 19,453
