key wont turn in ignition
steerings locked and key wont turn
Been there, done that.
The tumblers are sticking. You need to remove the entire ignition lock assembly. In my case I got another one from a junkyard and moved tublers from one lock to another.
You might get lucky and be able to clean it. For me, a good cleaning only seemed to help for about a week. Kept a can of WD-40, but that’s only a temp fix. WD-40 seems to attract dirt/dust.
There are Youtube videos on this. Its not too hard.
Also, I believe the dealer has a kit to replace. The kit comes with a selection of tumblers. You stick your old key into the new ignition and make sure the tumblers line up perfectly (and move smoothly).
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 4
今までの合計 90
