メインコンテンツにスキップ
Sony Computer Entertainmentによって製造されたPS4と通称で知られるテレビゲーム用コンソールです。2013年2月20日に製品の発表、2013年11月15日に発売されました。
1697回答 すべてを表示
PS4 Power Issue with Instant Blue Light (Second PSU)
Hi all,
I have a problem, I received a PS4 from a mate, its broken when plugged in a beep happens, a blue light appears for a split half a second and then the PS4 is off. I press the on button again and nothing happens until I unplug it and plug it back in.
Research online tells me its likely an issue with the power supply (PSU) so I bought a new one online. Replaced it and everything was great, working perfectly for over an hour, I updated it, played some games, installed some themes, everything was right with the world.
I then looked away for a minute to grab a drink, came back and it was off. I tried switching it back on again and I’m back to the same issue as before, blue light only on for half a second then off, need to unplug it and plug it back in to try again.
Anyone got any advice what it could be, what I could check? What are the chances the new PSU is faulty? I’m unsure if I went to spend another $30 on a PSU if it will break down again.
Thanks so much!!
edit—
Not sure if useful but apparent original problem was it got fried by lightning.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Have you tried adding a washer under each side of the APU clamp? Since you’ve already replaced the power supply I’m guessing that some of the solder joints between the APU and motherboard are faulty. A washer under each side of the clamp may fix that issue.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
I added a few washers but seems to be the same unfortunately. Went through with a multimeter on the motherboard and it looks like I'm getting quite a few shorts around the place, in particular I'm getting quite a few on a chip called "TI 53123A" https://www.psdevwiki.com/ps4/TI_53123A
Maybe it steps down the voltage and its whats zapping it and killing it? Not sure how easy to replace.
Thanks heaps though! Also are you the TronicsFix as in from youtube? Because I love your videos <3, really interesting to watch and I feel like I learn a lot! So good!
さんによる
Yep, that's me. I try to come on iFixit and help out in the forums whenever I can. Glad you're enjoying the videos!
さんによる
コメントを追加
回答を追加する
Calvin さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 7
今までの合計 359
