メインコンテンツにスキップ
ニンテンドー3DSは任天堂の最新モデルです。より大きいスクリーンに、より長くなったバッテリー寿命と改良されたデザインが特長です。
Can I unbrick my 3DS XL?
Two years ago, I tried to install something on my 3DS because I got a game from a friend that wasn’t compatible with my console. I found this guide https://3ds.hacks.guide/ and while following it, my 3DS stopped working. When I try turning it on, the screen stays black, but the blue light flashes once for like a second . I made some researches and it turned out that I apparently bricked my console? I was only 16 when I did this and was just so desperate to play Tomodachi life I had got from my friend, I didn’t really know what I was doing. I’m not really an expert at modding and such things, but I would really be happy if I could get my console to work again.
I dindn’t make a back up and I used the SD card that was in the 3DS when I got it which might also not have been the best move? Is there any hope left for my nintendo?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
4 件のコメント
I got a similar problem when the screen was bent too far backwards, and cannot get the system open because the screws are stripped. The console turns on for about three seconds, then shuts down. Activating a calibration function makes it stay on for about a half-second more. The system only stopped working after the lid was closed.
さんによる
I wiped the sd card years ago thinking I could never get it back. What do I do?
さんによる
@atrixsocialrbx follow the steps in my answer
さんによる
Yea just buy boot.firm from the luma file and place it onto the main page of the sd card.
さんによる
コメントを追加
7件の回答
最も参考になった回答
I know I am like a year late but to anyone having this issue: You need to download the latest version of Luma3DS and extract it to the root of your sd card. Make sure the boot.firm is on the root. Replace any files if it asks to.
このアンサーは役に立ちましたか?
スコア 3
5 件のコメント:
okay then what
さんによる
what should i do next?
さんによる
@Anthony Gomez did you find a solution?
さんによる
Just put the sd card back into the system, it should boot
さんによる
What if this doesn't work either
さんによる
コメントを追加
Try removing everything in the "sd://luma" folder and then getting the latest "arm9loaderhax.bin". Then boot into the config menu.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
you are still facing this issue
さんによる
コメントを追加
Try Holding L, R, A, and Up (on the directional pad, not the circle pad), then performing a system update. This fixed a “soft-bricked” 3DS. If this does not work, you may have to insert the SD card into a computer and perform a specific procedure for “hard-bricked” 3DS consoles. I found this on YouTube long ago. If you wish, you may click here for a video clip I have found, but not yet reviewed due to it being blocked.
このアンサーは役に立ちましたか?
スコア 0
4 件のコメント:
This is a problem with CFW, not his 3ds. He doesn't have a hard brick or soft bricked console. He just forgot some files on his SD card lol
さんによる
@johnodon Not to be rude, but he claimed that he forgot to back up his files, not that he forgot any. He may get a fix for this, but it is the best answer that I can give. The update may fix the firmware issue. Thanks for the comment!
さんによる
@michaeld2 Not to be rude, but my answer linked him all the files he needed, which were listed on the guide.
さんによる
@johnodon Your answer may be more helpful than mine. I am thankful for your contribution.
さんによる
コメントを追加
Mine comes up with a bootrom 8046 error and a bunch of error codes and help thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
if you have the naand back up
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
You have to reinstall Luma3DS and it should work. Had the same problem, now I have a home brewed and working 3ds!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
how do u do that? im facing the same issue
さんによる
コメントを追加
Yes go to stchix on YouTube for proper guide
このアンサーは役に立ちましたか?
スコア -1
1件のコメント:
no. do not use video guides
さんによる
コメントを追加
回答を追加する
julie さん、ありがとうございました!
統計データ:
過去 24時間: 10
過去 7 日: 70
過去 30 日: 460
今までの合計 28,720
