What are the different ways to repair nerf gun darts
I got a lot of bent and ripped nerf bullets can I repair them as I don’t want to chuck them away
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Once the foam is damaged there really isn’t a way to undo it, especially for something that needs to retain any aerodynamic properties. The best you could do is remove the ends from the foam and cut new foam from backer rod, but that’s probably more trouble than it’s worth.
このアンサーは役に立ちましたか?
thanks. me friends said heat the darts up in pillow case for 20 second or dip the dart in a pot of boiling for 1 or 2 seconds so thanks for the second opinion
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 581
