メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
iPhone 5S Stuck in Apple logo boot loop
I have recently dug my two old iPhone 5S’s out of a drawer and when pluggin one of them in the Apple Logo appeared for around 5 seconds and then dissapeared.
I though that it was just because it was a dead battery (due to sitting in a drawer for years) so left it to charge overnight.
The issue still occurs whenever I push the power button or plug it in. I have tried a known good charged battery and the same issue still occurs. I can not even get the device into DFU mode or Recovery mode as it just turns off. Any advice or possible solutions would be great.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
The battery has a built in over discharge protection chip.
This effectively locks out the battery when the voltage gets too low, when an iPhone cant read the battery it won’t really try to boot past the first part of the bootloader
Try a replacement battery
Where they put in the drawer in the first place due to this issue? :)
It can be something else wrong with the phone
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Hello,
These phones were put in the drawer due to upgrading and I accumulated a spare one of my father and they both worked before. I have tried a know good and charged replacement battery and the issue still occurs. Strange that the other iPhone worked fine but this one has decided to stop working
さんによる
there are very small components right next to the battery connector that can be broken off when chaning battery, if they are missing they can cause this fsult to
さんによる
A replacement battery usually solves this.
Externally charging the battery with sometime like this would make the battery work but it's better just to get a replacement battery as it's fairly hard to remove one without damaging it:
https://www.aliexpress.com/item/Kaisi-K-...
さんによる
コメントを追加
回答を追加する
Mark さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 52
