メインコンテンツにスキップ
HD action camera with touchscreen LCD, released October 5, 2014.
87回答 すべてを表示
Gopro only works if in the freezer! Hahaha
Gopro in the freezer is the only way I can get it to work. But it only works until it warms up. I replaced the image sensor and it still does it. I tried putting only the battery in the freezer and nothing. Somehow the freezer if fixing it but only for like 2 minutes. Please help. Thank you so much!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Might be a solder connection that has gone bad. As metal expands and contracts in heat and cold, the difference in temperature could cause a solder joint to get a good connection when cold, and loose the connection when hot. Inspect the board with a magnifying glass for any obvious faults. Using a hot air gun you could try to reflow all the solder joins on the PCB. Hope this helps!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Angela Poston さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 4
今までの合計 205
