メインコンテンツにスキップ
Released in June of 2009, the 1005HA is identified by its "Seashell" design, and is available in many different varieties in regards to operating system, internal storage, and battery size.
20回答 すべてを表示
1005HA LVDS cable: Is 14G2235HA10 equal to 1422-00ML000?
Hi.
Looking for a replacement LVDS display cable for my EEE PC 1005HA. It takes a 14G2235HA10, and I've seen some vendors advertise a cable labeled with both this number and 1422-00ML000. Other vendors use just one or the other of these numbers.
Anyone know whether the 14G2235HA10 and the 1422-00ML000 are exactly the same cable with the same connectors?
The ASUS support site lists only the former number (http://support.asus.com/Search/KDetail.a...).
Thanks for your help.
--Frank
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
My research suggests that the cable is the same but it is based on the information supplied by various vendors I have found on the internet - much like you have. I'd stick to the primary number on the faulty cable and/or the number provided by ASUS
Update
Thanks much, Richdave! I took a chance and am happy to be able to answer this question affirmatively: the 14G2235HA10 IS apparently equivalent to the 1422-00ML000 cable.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
yes, they are compatible lcd cable
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Frank DeSanto さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 3,275
