メインコンテンツにスキップ
Kindle Fire HD 6 (モデル番号PW98VM)は6インチのエコノミータイプのタブレットで、2つのカメラ、1つのスピーカーとAmazonのFire OSが搭載されています。
21回答 すべてを表示
Where is the LCD connection inside the kindle Fire 6HD?
Question: Where is the LCD connector in the Kindle fire 6HD. I have enclosed a photo of the open item. Please tell me where is the LCD connector?
Hello, I replaced the screens on two Fire HD6’s on the first with the badly shattered screen I managed to break one of the zero force connectors (my bad). On the second I did every thing according to plan and I can hear that it is turning on as messages ping in but the screen will not light up to touch or to turn on. I have reassembled this little beast three times to no avail…what might the problem be. It was working just find prior to my replacing the cracked screen (which was accomplished with no problem or unusual force being used). I was extra careful to make sure the zero force connections were done properly as well. Thanks
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
I have found a teardown that should show where the screen connectors are. Hope this helps!
Kindle Fire HD 6 スクリーンの交換
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sisterpine さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 61
