メインコンテンツにスキップ
Is there any way to open my power adapter?
My Asus g73sw charger adaptor I bought seems in very new condition but as I plug in to the wall the light on the box doesn't turn on. That's why I'm wondering how do you open this type of charger? Just want to see if any capacitors aren't burnt or leaking since that can be causing the problem?
The 2nd picture I believed I some type of screw but not sure if I can removed them since it looks it has a pin in the middle of the screw.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Hi @fernando21 ,
If it is new and there is no output when tested by a Voltmeter, contact the seller about a warranty replacement.
Do not void the warranty by trying to open it.
さんによる
@jayeff I practically got this charger adaptor for free better than the old one I have since looks new from the outside but most likely has an issue in the inside. Last time I use a multimeteter on it I didn't get the voltage that it was suppose to come out.
さんによる
コメントを追加
2件の回答
ベストアンサー
I found out how to open it up you need a special type of screw adaptor tip. I opened it up inside it looked very damaged even the board was cracked. I think someone try to fix it but couldnt done it.
No voltage with multimeter
Thanks for replys guys.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@fernando21 ... welcome
さんによる
コメントを追加
最も参考になった回答
Hi @fernando21
I would suggest checking the power adapter first using the multimeter to confirm for any DC output voltages.
What kind of adapter were you provided with? the square one or rectangle one?
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
@salmonjapan I updated the post with pictures and I believed I might need special screw driver to remove these screws . Yes it sqaure power adapter. Thanks for responding as well.
さんによる
コメントを追加
回答を追加する
Fernando さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 126
