Why does my washer not go from the wash to rinse cycle?
My Maytag MVWB765FW3 cycle time will not go down from 54 minutes. It continuously stays in the wash cycle.
Lid Switch
The lid switch is a safety feature found on most top loading washing machines. The lid switch is normally located beneath the main top with a projection on the lid or a pin attached to the lid that will actuate the switch when the lid is closed. The lid switch supplies power to the timer and motor circuits. Verify that the switch is being activated mechanically and that any levers or actuators are not damaged or sticking. If the switch is being activated but there is no power being supplied to the timer circuit then the switch may be defective. Disconnect power from the appliance and remove the wires from the switch. You can then check the switch for continuity with a multi-meter. We strongly recommend that you DO NOT bypass a lid switch as it is an important safety feature and serious injury could result.
The timer is used to control all of the functions of the washer. The timer will have a series of electrical contacts that are operated by a cam assembly which is advanced by a timer motor. Some of the contacts in the timer are used to control the timer motor. If the timer on your washer will not advance, the timer or timer motor may be at fault. You can test the timer contacts for continuity with a multi-meter but you will require the electrical schematic to determine the correct terminals to check. You can also check the timer motor for continuity with the multi-meter as well. On most brands of washing machines, the timer motor is not available separately. Remove power from the appliance before attempting this test.
The water level control on washing machines is used to turn the water valve on and off at the selected levels, as well as to supply power to the timer motor when the correct water level is reached. If your washer fills but the timer does not advance you may have a defective water level switch. When the water inlet valve shuts off you can then check the water level switch for continuity with a multi-meter. Remove power from the appliance first and then remove the appropriate wires from the control before performing the test. Verify the proper contacts to check with the schematic diagram.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 17
今までの合計 155
