While I drive my rpm jumps and my car goes into a neutral like state?
While I drive my rpm jumps and my car goes into a neutral like state for a minute or so.Any clue to what may cause this? Car:2005 New Jetta
この質問は役に立ちましたか?
この質問は役に立ちましたか?
I have the same car/same year with 209k miles. My unit initially manifest your question described symptoms gradually starting only when you’d “jump on it” make a request for acceleration and it would over-rev the tach with no related presence of actual acceleration.
Lived with that for 1 year until going down the road at 70 mph, the tach would flicker up & down +/- 200-500 rpm inepite me actuating no change in the foot position of the accelerator pedal.
That trans failure was described as “neutraling” by the reputable shop I at length consulted with.
They said with clocklike reliability, they see VW auto trans going for 150k-225k mile intervals between major systemic failure. I ordered and bolted on a reman.
このアンサーは役に立ちましたか?
So Wat was the main problem that was causing that
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 176
