メインコンテンツにスキップ
Device name is Jensen 3 speed stereo turntable. Model is JTA-230.
9回答 すべてを表示
Tone Arm Skips / Turntable turns unevenly
1) The tone arm seems too lightweight and skips and skates over my records.
2) The turntable does not spin at an even rate. I am not referring to pitch control. I can clearly hear that the record is not playing evenly.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
sounds as if your anti skate needs adjustment, it should be almost the same as the counter weight adjustment , Also your belt should be replaced or if you have a direct drive it may be the motor speed adjustment or motor is malfunctioning there are manuals available on line
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Thank you for your response regarding the JTA-230 Turntable. There are just too many problems with this product that should not occur with a NEW out-of-the-box product. I had high expectations for this product based on the customer comments on Amazon as well as the price. Unfortunately, I will be returning it. Perhaps there is a better product out there.
さんによる
i recently bought a dual 503 from used site for 100.00 works great ,most of all built right and use it daily unfortunately i fell for the cd racket and sold my old dual with records now kicking myself .best of luck
さんによる
コメントを追加
Sometime you need to clean and check or replace your needle with a new one. Built up dust on the needle or stylus can can this. Or it may need the needle or stylus replaced.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brant Casey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 15
今までの合計 814
