How much the replacement usb charging port
Hi, how are you?
My TI-84 Plus CE mini usb charging port was broken.
So how much fix charging port?
Erm, I’m not sure how to interpret your question, so I’ll answer all of my interpretations.
Before I go into how you’d replace it, I want to make sure that it’s the port that’s broken and not something that’s much easier to replace. Have you tried using a different Mini USB to USB type A cable? Does your current cable charge other devices just fine? Have you tried plugging it into a different power source? i.e. instead of plugging it into the wall adapter, try plugging it into your laptop (and vice versa). If you’re sure it’s the port, then here’s how the replacement process will probably go for you. Only attempt this if you are comfortable with soldering! Or if you don’t care about accidentally breaking your calculator more. (NOTE ''''I have never attempted this exact repair before)
Here’s a picture I think you’ll find useful:
Good luck with your repair!
ガイド
難易度:
簡単
1 - 5 minutes
ガイド
難易度:
簡単
5 seconds - 10 minutes
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 7
過去 30 日: 39
今までの合計 1,632
