メインコンテンツにスキップ
The Magic Bullet NutriBullet Pro 900 Watt Blender is a small-sized blender used for blending up veggies and fruits.
12回答 すべてを表示
Why does the cap unscrews will blending causing the liquid to leak out
Why does cap unscrew while blending causing liquid to spill into base?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
6件の回答
最も参考になった回答
Let’s see if I have this correct. You take the container with the top off, fill it with stuff you want to blend, screw the cap with the blender blade on. Then invert it, put it on the blender, blend then remove it and take the cap off to access the contents.
Now you want to know why the contents leak out when you unscrew the cap.
Do you live in one of these green states?
このアンサーは役に立ちましたか?
スコア 1
5 件のコメント:
The content begins to leak out as it is blending. The cap unscrews itself.
さんによる
Change the gasket or tighten the lid down.
さんによる
I rub a bit of coconut oil on the rim of the cup then screw on the blade attachment but do not over tighten. No more leaks!
さんによる
"Why does cap unscrew while blending causing liquid to spill into base?" Reading comprehension is hard in a low educational ranked state like Texas huh Boomer..
さんによる
"Make it tighter".. Genius.. (eyeroll) @mayer
さんによる
コメントを追加
I have same problem. I purchased new gaskets & new containers. The new gasket worked for a few months but problem has returned.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It’s resistance on the blades that is unscrewing the cap! If you’re mixing soft fruit and liquid only, this wont happen. An overloaded cup and/or hard items such as carrots Ice and the like is also problematic. cut the these things fine or crush them before placing in the cup and add water. Another thing to watch is those little lugs on the cap that insert into the slots that start the motor, push down only to pulse..if it pulls to the lock position on its own trouble usually ensues! Anyway this has been my experience, I hope this is of some assistance.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
yeah I only blend soft stuff and it happens 3 out of 5 times. And I am making it very tight. Its a bummer because the form factor is right on. Don't want a full blender..
さんによる
コメントを追加
I have tried 2 different Bullets, they both leaked from the very start. Will purchase a different make.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I am having the same issue....(@Cannon I am highly educated in the sciences). My former Nutribullet did not do this. However my new Nutribullet Pro is doing this consistently. It does not matter how tight the cap is, it will always open. Like I said earlier, the Nutribullet NEVER did that regardless of the contents inside the cup. Is this a bad item or is the whole line flawed?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Simple solution. Just put a thin rubber band around the outside of the blade attachment so that when you push it into the mixer it is a bit tight and will not move easily when spinning.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Carrie M Williams さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 28
過去 30 日: 101
今までの合計 4,760
