メインコンテンツにスキップ
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
55回答 すべてを表示
Plugged to AC bricked the phone
so , i have a G6 i was using a samsung aftermarket fast charger QC3.0 , just when plugged it in the phone vibrated couple times (like of plugging and unplugging the cable) then turned off completely , and won’t turn on tried hard reset .. etc
when i plugged it to the car 12v charger the light of the 12v charger turns off when i just plug the chable in the phone , and turns back on when i take it of the phone (like the phone stopping the electricity )
so i want to know whats faulty , is it the charging port , or the whole Motherboard ,
PS: the electricty in that room is not good at all , after the incident i knew that i burned 2 phones charging port !
edit: opened the motherboard and found this i think its blown
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
LG’s have a notorious issue with burning themselves out, but in this case id get another board. unless you wanna pay someone to microsolder and fix your board which might be as much as getting another phone. also.. try letting the phone discharge a couple days and then plug it in for 24 hours in a different set of sockets
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
mokhled997 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 348
