メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
Why my Barista start dripping the espresso very slowly out
It stopped pouring the espresso like used to be now is just dripping very slowly. It took me 10 minutes to make a single shot of espresso this morning. I love that coffee machine i been having it from 10 years.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
You're most likely looking at one or a combination of these issues:
- Coffee ground too fine
- Coffee tamped too hard in the basket
- Brew screen clogged
- Portafilter clogged
Does water flow through easily with the portafilter removed from the machine? Then your screen is probably fine. Does water flow through the portafilter easily when there's no coffee in it? Then your portafilter is probably ok. You're then looking at a grind/tamp issue, not a problem with your machine.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Yes, remove the shower screen and CLEAN the group head and the screen.
I did not see this in the instructions, so this task is likely missed by many.
I had one machine where there was sooooo much coffee residue behind the showers screen that NO water could get through. And every hole in the shower screen was plugged. Gave it a good cleaning and it worked fine.
さんによる
コメントを追加
This unit is likely the same as the Rio Vapore - HERE is the manual
Page 28 - troubleshooting may assist
These iFixit Starbucks Barista Guides may be useful too!
HIH
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
It has happened to me and I went to several forums to try to fix it and it just wouldn't work. In despair I just used CLR, or a generic Calcium Lime and Rust cleaning spray directly on metal filter container and VOILA worked like a charm. I just sprayed the metal cup and inside the portafilter, let it sit for some 10 mins then rinse very very well. Unbeknownst to be, I have hard water and the little holes where coffee was supposed to go thru were clogged.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
pavel zlatev さん、ありがとうございました!
統計データ:
過去 24時間: 14
過去 7 日: 72
過去 30 日: 292
今までの合計 43,898
